jza80 to jzx90/100 brake upgrade bolts
Posted: Mon Jan 17, 2011 6:42 pm
found this diagram a little while ago to make the spacer bolts to allow you to run jza80 4 pots on your x90/100
this is by no means my idea
i found it on another web site and saved the pic
hope it helps
Re: jza80 to jzx90/100 brake upgrade bolts
Posted: Tue Jan 18, 2011 12:35 pm
by crux
Cheers, perhaps someone will make these up in NZ eh? I was intending to buy the Nightpager set or the Figs ones when I do my Supra brake upgrade.
Posted: Tue Jan 18, 2011 5:53 pm
by VR25
Settle with nothing else , the figs adapters are perfect !
Posted: Tue Jan 18, 2011 6:05 pm
crux wrote:Cheers, perhaps someone will make these up in NZ eh? I was intending to buy the Nightpager set or the Figs ones when I do my Supra brake upgrade.
comes down to how skill full you are with tools and metal
i would go with the night pager ones for around $80 odd nzd when i last looked on yahoo jay pan ( last yr ), thought it was cost effective to just import them
but more info the better
Posted: Thu Jun 28, 2012 6:00 pm
by Weekend_Millionaire
Where's the most easy place to get these in NZ?
Posted: Thu Jun 28, 2012 7:23 pm
no where
you can either make them from the diagram i posted above or import them from the likes of night pager or figs engineering in the states
Posted: Thu Jun 28, 2012 7:30 pm
by driftouteast
These would be pretty easy to make up. Take the drawing to a local engineering shop
Posted: Thu Jun 28, 2012 8:17 pm
easy but costly unless you are pumping them out by the metric fuck load or you know someone
most places will charge you around 40 to 50 a nut
they are $100 to buy ex states or japan
Posted: Sat Jun 30, 2012 8:55 pm
by Hoadster
I found a great deal on front oem replacement supra cross drilled rotors. Would it still be worth it to upgrade? Would it even be possible without supra calipers? I have a gx100 mark ii 5 speed.
