Upgraded brakes for a GX100
Do you guys know what size rotors you can run on a GX100, or if there's a limit? Are you just restricted by the size of your wheels? I have 17's on right now and have been looking at used supra bbk's. Thanks fo the help guys.
Re: Upgraded brakes for a GX100
you will be sweet with the 17" and the BBK on the gx100 ( edit do the gx100 run the same control arm as the jzx100s? )
however its the calipers that will cause you the most gref as some wheels dont always clear them
Update: I picked up a pair of Z32 rebuilt and powdercoated front 4pots for $60 bucks. I know these can be fitted to my gx100, but cant find the thread. Anyone done this? I need answers..
Anyone know where I can pick up some RCA's? As it turns out, the Supra kit was difficult to find, but I was able to source UCF20 rotors and calipers. From my understanding, I'll need Roll Centre Adjusters in order to run these effectively.
I bought my RCA's from Yahoo Japan. They're a cheap part, can get some no-frills ones for peanuts or pay a bit more for fancy anodized ones that come with stickers etc
You're in Japan aren't you? Should be easy to find over there...
