Removing rear struts on JZX90/100
Hoadster
Post by Hoadster »
Have any of you done this? I was toying with it earlier, but i couldnt get them free. Any help is appreciated!
ch4sernz
Re: Removing rear struts on JZX90/100
Post by ch4sernz »
long bar hooked through lower arm with a friend standing on it.
remove old struts, replace with much shorter adjustable coilovers to make reassembly much easier!
Logan
Looonie
Post by Looonie »
Disconnect swaybar if you have it too.
But yeah, had to use crowbar and in excess of 100kg of downweight to move the upper a-arm enough to get strut out... stupid annoying things.
Or just unbolt and remove ;)
Hoadster
Post by Hoadster »
Just using a crowbar wont damage anything??
2win2rbo
Post by 2win2rbo »
You'll have to fully collapse the wishbones and the strut-coil assembly will have to pass in between the wishbones at an angle. That's what we did, at least.
It would be much easier if the bolts fastening the wishbones to the chassis are loosened. That way, you won't need anyone to push them down.
1993 トヨタ クレスタ TOURER S JZX90
archon
Post by archon »
On the 110 the key was to bring the top of the strut out past the guard. Front suspension was the opposite. I got full suspension swap down to about an hour (every 6 months 8-) ) when I had coilovers. I can't picture either 110 or 100 setup at the moment so this may be of no use to you....
archon wrote:On the 110 the key was to bring the top of the strut out past the guard. Front suspension was the opposite. I got full suspension swap down to about an hour (every 6 months 8-) ) when I had coilovers. I can't picture either 110 or 100 setup at the moment so this may be of no use to you....
basicly what this man has said
really not that hard
undo sway bar links ( if you have them
lift car high as possible so the arm are at the lowest point
undo bottom bolt
then the top three strut should slide out easy
with the fronts you have to undo the top A arm and do it that way
so do not remember using and JB10s haha
