Jzx90 lock kit and wheel alignment
Posted: Sun Nov 10, 2019 10:49 pm
Hi All
Just wandering who all are running Kazama lock kit setup. I have recently purchased below from the team at Genesis Massive:
knuckles
lower control arm +25mm,
extended tie rod end +35mm,
strengthened tie rod and adjustable caster rod
I was told that even with the new mods, i could go to any local wheel alignment shop but thats been a mess.
Any recommendations for Auckland base shops to get drift spec wheel alignment done (impossible to get in touch with GM again)
Also whos running the similar or different set up as above, keen to understand you experience around wheel alignment set ups
knuckles
