sexy10 altezza front lca's in jzx90? (not the castor rods)
No point in having a million kw and not being able to use it...
Matt K
Post by Matt K »
anyone tried this at all? seems no one has.
im assuming altezza ones are longer, so might get a camber gain and more steering.
can anyone measure how long an altezza lca is from center hole to center hole?
cheers.
Re: sexy10 altezza front lca's in jzx90? (not the castor rod
Post by davealdworth »
I thought the front suspension gear on the front of the sxe10 was the same are the 90/100 as well, i definitely know its the same as the 110. I know the rear set ups between the 90 and sxe10 are completely different.
Matt K
Post by Matt K »
well... i know the caster rod bolt sizes are different. sexy 10 altezzas being bigger to jzx90
the differences between the length, however... ?
