jzx90 brake upgrade
Posted: Tue Jan 13, 2015 10:40 am
by xMRWHIPPIEx
hey guys.
i'm looking at getting some slotted rotors and new pads for my JZX90 Cresta, have any of you guys done this? if so, what rotors did you use and what pads would you recommend?
i would be looking for a fast-street pad.
i have rung Znoelli's to get hold of pricing, however, they said that most likely i would need to get rotors made to order as the JZX90 is an uncommon vehicle...
cheers
Re: jzx90 brake upgrade
Posted: Tue Jan 13, 2015 10:43 am
by gtivvl
stock soarer discs same?
Posted: Tue Jan 13, 2015 10:50 am
by xMRWHIPPIEx
i don't believe the ZZ30 discs are the same as X90 :L i think they are the same as X100 however.
i could be wrong... i hope i am, cause Soarer discs are much easier to find.
Posted: Tue Jan 13, 2015 11:33 am
by davealdworth
I'm going through a brake upgrade list for the 90/100 and have found a couple of pad combos that can be used. So far for just rotors i have found
Biot 1/2 piece
Acre
Dixcel
Endless
Ideal
KTS
The jza80 rotors fit apparently too its only the caliper mounts that need modification when you use the jza80 4 pots.
Posted: Tue Jan 13, 2015 1:47 pm
by xMRWHIPPIEx
never mind....
i may have caved in and just bought a Supra BBK kit off Nick at NST hahaha FML
Posted: Tue Jan 13, 2015 2:28 pm
by ch4sernz
Best way forward in your situation
Posted: Tue Jan 13, 2015 2:56 pm
by xMRWHIPPIEx
ch4sernz wrote:Best way forward in your situation
yeah, you're right, the wallet is certainly feeling super light haha
Posted: Tue Jan 13, 2015 4:18 pm
by davealdworth
are you getting the offset nuts too?
Posted: Wed Jan 14, 2015 9:46 am
by xMRWHIPPIEx
Bought the 'kit' from Nick at NST
comes with offset nuts
Posted: Wed Jan 14, 2015 12:19 pm
Damn that's sexy
