JZX110 suspension basic info
No point in having a million kw and not being able to use it...
Post by davealdworth »
Hey team.
For any of those 110 owners out there looking for coilovers, I have smashed together some information (mainly for myself) with brands, spring rates and links available. I know this isn't all options that are available but these are the standard sort of brands that are used around the track without going ridiculous such a 326 Power gear. In addition as the SXE10 suspension is the same, where a JZX110 option isn't available i have made reference to the SXE10. Feel free to use this, just thought a bit of info could be nice for those new to the 110.
BC BR TYPE RS (SXE10)
Front - 10kgf/mm Rear - 6kgf/mm
Top Mount - Rubber
http://www.bc-racing.com.au/bc-racing-c ... 01-rs.html
BC ER SERIES (SXE10)
Front - 14kgf/mm Rear - 10kgf/mm
Top Mount - Solid
http://www.bc-racing.com.au/bc-racing-c ... is300.html
BC V1 Design VA (SXE10)
Top Mount -Solid front /Rubber rear
http://www.bc-racing.com.au/bc-racing-c ... 01-va.html
BC V1 Design VS (SXE10)
Top Mount - Rubber
http://www.bc-racing.com.au/bc-racing-c ... -1727.html
BLITZ DAMPER ZZ-R
Top Mount - Solid
http://www.blitz.co.jp/products/suspens ... _zz-r.html
BLITZ DAMPER ZZ-R Spec-C
Top Mount - Solid
http://www.blitz.co.jp/products/suspens ... pec-c.html
BUDDY CLUB PRO SPEC (SXE10)
Front - 12kgf/mm Rear - 8kgf/mm
Top Mount -Solid
http://www.buddyclub.jp/p_al_damper/ind ... #al_lineup
CUSCO STREET ZERO
Front - 14kgf/mm (12k/16k/18k) Rear - 10kgf/mm (9k/11k)
Top Mount - Rubber
http://www.cusco.co.jp/en/catalog/pdf_c ... erkit.html
CUSCO STREET ZERO A
Top Mount - Rubber
HKS HIPERMAX MAX IV GT
Front - 16kgf/mm Rear - 12kgf/mm
Top Mount - Rubber
http://www.hks-power.co.jp/en/product/s ... index.html
HKS D' NOB SPEC
Front - 16kgf/mm Rear - 14kgf/mm
Top Mount - Solid
HSD MONOPRO (SXE10)
Front - 12kgf/mm Rear - 10kgf/mm
Top Mount - Solid front /Rubber rear
http://www.hsdcoilovers.com/hsd-coilove ... zs161.html
HSD DUALTECH (SXE10)
Front - 12kgf/mm Rear - 9kgf/mm
Top Mount -Rubber
JIC FLT-TAR
Top Mount - Solid
http://www.jic-magic.co.jp/suspension.html
LARGUS
Top Mount -Solid / HD Rubber
http://largus.co.jp/products/damper/index_e.html
RACING GEAR HS DAMPER
Front - 12kgf/mm (Optional of 6-22k) Rear - 10kgf/mm (Optional of 6-22k)
Top Mount - Solid
http://www.racinggear.co.jp/hs.html
RACING GEAR ZX DAMPER
Front - 14-16kgf/mm Rear - 10-14kgf/mm
Top Mount - Solid
http://www.racinggear.co.jp/zx.html
SILK ROAD RM/A8
Front - 10kgf/mm Rear - 7kgf/mm
Top Mount - Solid
http://www.d224030.win-sv.com/eccube/ht ... skita8.php
TEIN MONO SPORT DAMPER KIT
Top Mount - Stock needed
http://www.tein.co.jp/e/products/mono_sport.html
TEIN STREET BASIS
Front - 8kgf/mm Rear - 6kgf/mm
Top Mount - Rubber
http://www.tein.co.jp/e/products/street_basis.html
TEIN STREET ADVANCE DAMPER KIT
http://www.tein.co.jp/e/products/street_advance.html
TEIN STREET FLEX DAMPER KIT
Front - 10kgf/mm Rear - 8kgf/mm
http://www.tein.co.jp/e/products/street_flex.html
TRUST GReddy PERFORMANCE DAMPER Type-S
Front - 10kgf/mm Rear - 9kgf/mm
Top Mount - Solid
http://www.trust-power.com/06sus_spring ... umper.html
ZEAL FUNCTION X Plus (Hard Spring Version)
Front - 20kgf/mm Rear - 16kgf/mm
Top Mount - Solid
http://www.endless-sport.co.jp/suspensi ... tionX.html
ZEAL FUNCTION X Plus (Soft Spring Version)
Front - 18kgf/mm Rear - 14kgf/mm
Top Mount - Solid
ZEAL SUPER FUNCTION
Front - 22kgf/mm Rear - 18kgf/mm
Top Mount - Solid
http://www.endless-sport.co.jp/suspensi ... ction.html
ZEAL FUNCTION A TYPE
Custom spring rates
http://www.endless-sport.co.jp/suspensi ... n_com.html
ZEAL FUNCTION T TYPE
Custom spring rates
JZ14
Re: JZX110 suspension basic info
Post by JZ14 »
shout out to dangerousjzx110 @ JZX100.com for making this.
Haha yea that's me lol. I have one in the works for brake set ups too.
JZ14
Post by JZ14 »
You should be DangerousJZX110!
haha I've just added up a list of the brake upgrade options for the jzx110 including conversions from the IS200/300 and a few of the better priced jza80 conversion kits too.
For anyone interested check out this list here
http://www.jzx100.com/forum/topic/15950 ... t-options/
I'm also now starting to go through jzx90 and 100 lists too any requests no list is too undoable (yes that is now a word)??
xMRWHIPPIEx
Post by xMRWHIPPIEx »
davealdworth wrote:haha I've just added up a list of the brake upgrade options for the jzx110 including conversions from the IS200/300 and a few of the better priced jza80 conversion kits too.
a brake upgrade/conversion list for JZX90 would be awesome! (rotors, pads & calipers if you can be bothered)
Sure thing bro, will get it done this week
Hey guys
Here's another update this time for the 90/100 boys. I have a list that's currently for the OEM pad and rotor combinations available. I am still working on this list to include the rotor upgrades and BBK's that are also available.
http://www.jzx100.com/forum/topic/16046 ... z3RqneLtW9
