TRD LSD
crux
TRD LSD
Post by crux »
Hey guys, didn't know where to put this as there isn't a driveline section heh.
Anyway, supposedly my car came with a TRD LSD. Initially it was tight etc, but recently it has become crap to the point it'll only lock up two wheels pretty much at full power.
I do intend to do a bit of drifting/racing with this car so I am looking at my options.
Anyone have a TRD LSD and rebuilt one themselves? Taking the diff out myself is no problem.
Anyone had experience with the TRD rebuild kits?
Im just afraid, I'll order the rebuild kit and after I take out the diff, find out its just a worn out factory torsen or something hah.
The diff is completely lacking over my previous Cusco 2-way GT Pro, so any suggestions would be great!
xnickx
Re: TRD LSD
Post by xnickx »
Sean I would recommend taking the diff out, and inspecting it first, so you know what you are dealing with, as TRD rebuild kits are fairly well priced ;)
If not, TRD LSDs are super cheap these days, $1280.00 including GST (used to RRP at $1866.36+GST for the 8.0" LSD not long ago!)
ch4sernz
Re: TRD LSD
Post by ch4sernz »
Or quoted from Northland Toyota $7500 +gst... but we can do that to you for $1500 on indent order
That was about a year ago
Logan
Re: TRD LSD
agree pull it out and inspect
find out if its a plate type lsd or mechanical lsd
take note as to which bearing and spacerd goes wear too, will make life alot easier when setting bearing pre-loads later on
Mike
Re: TRD LSD
Post by Mike »
take it to steelie gears, maybe the oil used was crap and its worn out the plates?
seems weird tho. I agree Cusco is the best you can buy.
crux
Re: TRD LSD
Post by crux »
Funny thing was I used TRD fluid in there as well. Not as cheap as normal fluid. I only use standard LSD oil in my other 2-way so its a tad weird. Oh well, still yet to take it out! Heh.
crux
Re: TRD LSD
Post by crux »
Bugger, looks like a Torsen to me :(
Unstable
Re: TRD LSD
Post by Unstable »
yup... sure does bro.... Cusco time.
speedracer_nz
Re: TRD LSD
Post by speedracer_nz »
has anyone ever had to rebuild a torsen lsd unit itself before?
crux
Re: TRD LSD
Post by crux »
You can get Torsen rebuild kits, however judging by how they work I don't really see what there really is to wear out in the first place?
BTW, got a TRD LSD going in :)
