morning all
just wondering if any of you can confirm/advise if the link below will be the right bushes for my 1993 JZX90 cresta
http://www.nolathane.com.au/do_segue.ph ... 10%2F88-93
the listing states the bushes are for the 88-93' Cressida, apparently 93' is a changeover year...
Just looking to replace the front swaybar D-bushes.
alternatively, if you have experience or advice on alternative routes that would be great.
cheers
jzx90 cresta swaybar bushes
- Contact:
Re: jzx90 cresta swaybar bushes
Just get them from Autolign bro.. Then you can return if its wrong.. Andrew has the hookups i believe..
It's Joe Btw.
It's Joe Btw.
- Contact:
ah kia ora cuz!JZ14 wrote:Just get them from Autolign bro.. Then you can return if its wrong.. Andrew has the hookups i believe..
It's Joe Btw.
yeah i rang Autolign and spoke to Tony but they had no nolathane listing for JZX90, which sounds strange.
He suggested i measure the sway bar diameter, then if its between 13-30mm just run a universal D-bush.
no worries, ill keep geezin'.
Thinks SuperPro do a bush for this.
