Changing rear axle jzx90/100
No point in having a million kw and not being able to use it...
CHA5ER
Post by CHA5ER »
Hey guys,
Has anyone tried changing rear axle for jzx90/jzx100 before?
Well, the CV boot on one side has ripped and I want to get the rear axle out but its stuck!
Tried hammer and even the hydraulic axle removal thingy as well.
Can anyone help?
Thanks in advance
Jun
http://www.NBUSnz.co.nz <- The Best tints.
lolyf
Re: Changing rear axle jzx90/100
Post by lolyf »
Could you be a bit more precise? Whats stuck? Outer CV splines stuck in hub which is the usual abortion one goes through come cv joint time.
I suoprt pulik ejukashun!
luc3unitJZX
Post by luc3unitJZX »
Wheel off. Take axle nut off, Then the 6 inner axle bolts to diff. Pull it toward wheel, it will drop down then the outer should pull out of hub
