SO, looking at buying a set of D2 suspension as I can get a set for 900.
I've heard that the first gen stuff was complete utter s***. The second generation ones are apparently quite good. Does anyone have any other testimonys regarding the D2 adjustables or have any experience with them?
Please and thank you
D2 Suspension
Re: D2 Suspension
Driftmonkey wrote:SO, looking at buying a set of D2 suspension as I can get a set for 900.
What are you using them for? Daily or tracking
- Driftmonkey
Re: D2 Suspension
Daily for now, in the future maybe the odd trackday.
Re: D2 Suspension
Why not go for a nice spring and shock set up? D2s will be really agressive as a daily
Re: D2 Suspension
If you are going for coilovers i'd go BC Golds as they aren't much more and perform better.
Re: D2 Suspension
if you want lower go springs. if you want less body roll do sway bars and tires. much better value for $$$
Re: D2 Suspension
Springs suck, don't bother
- Driftmonkey
Re: D2 Suspension
Haha, it's currently low enough that it has no body roll whatsoever and rubs quite a bit. I have linglong tyres on the back for... reasons.Alex wrote:if you want lower go springs. if you want less body roll do sway bars and tires. much better value for $$$
- Driftmonkey
Re: D2 Suspension
They look to be 600 more from what I can see, but thats probably cause I don't know anyone who sells them. Only reason I'm upgrading is because I can get these D2 for cheap.Tofu wrote:If you are going for coilovers i'd go BC Golds as they aren't much more and perform better.
Re: D2 Suspension
going lower does lower center of gravity abit, but roll center ends up stuffed if you go too low without roll center adjusters. my advice would be if you want low and good handling, get RCA's and uprated swaybars, cusco being my choice. for a daily coilovers are overkill. and d2's spring rates are WAAAy too high for our crappy roads.
