altezza torsen in gx100?
gtivvl
Post by gtivvl »
does anyone know if altezza torsen will bolt into a gx100?
from what i can tell they have the smaller 7.5" diff like altezzas, unlike the 8" in the jzx100s
HeapsThorn
Re: altezza torsen in gx100?
Post by HeapsThorn »
Should bolt up sweet. Is your diff code on your firewall something like A01B??
Looonie
Post by Looonie »
I haven't done it, but all indications are that it should fit up just fine.
I was going to put an altezza torsen into my old JZX91, then discovered it had the bigger 8" version. Yours being the smaller 7.5" should take the Altezza one without a problem.
gtivvl
Post by gtivvl »
A04A actually, not sure what that actually means, online resources seem to only be able to deciper old toyota diff codes
tourist
Post by tourist »
A=7.5 04=4.3(I think) A=open
If its auto its probably 4.3.
gtivvl
Post by gtivvl »
its a manual w55. a usually means open but lsd has alot of diff codes, I have seen 'b' open and 'b' lsd as well
tourist
Post by tourist »
Well mines A04A and its 7.5 inch 4.3 open
So im pretty sure yours will be too if it aint been changed
gtivvl
Post by gtivvl »
so altezza torsen will fit? i think the code ia A10B for the one im looking at which is 4.1
Looonie
Post by Looonie »
Diff codes don't mean shit in later model Toyotas when it comes to the size of your head/cp.
gtivvl
Post by gtivvl »
sweet ill grab one in the near future and try my luck
