It is currently Sat Dec 22, 2018 11:22 am
Post new topic Reply to topic  [ 3 posts ]
  Print view Previous topic | Next topic
Author Message
PostPosted: Sun Sep 25, 2016 5:24 pm
Offline
Hi guys,
It is a sad occasion that I have joined this club. I've come in desperation. I seem to have purchased a Toyota that nobody else in the country seems to have except me and I'm feeling it in the lack of parts department.
My girlfriend had a low speed accident due to one of the wheels wanting to come away from the chassis. It came off the lower ball joint due to all the bushes being stuffed. It was only a few days off going in for a warrant too :(
Now I have a shot ABS sensor, a bent electronically controlled magnetically dampened shock to deal with. Luckily the hub isn't bent. I got the ball joint to get it rolling again and had it towed home. I'm told the bushes and ball joint on the other side is just as bad as well as the bush behind the diff and other bushes. Bottom line pretty much is I want all the bushes so I can avoid this in future.
I've recently just purchased the whole bush kit for my MR2 SW20, but according to wreckers, nobody drives this car and thus parts are scarce. I'll be contacting Toyota on Monday to see if I can get the shock absorber and ABS sensor from them, but I want all the bushes too, and I doubt Toyota would still do those.
How many parts are interchangeable between the JZX 80/90/100/110 chassis that would be compatible with the JZX101? I hear from some that the JZX101 was a completely different chassis with different parts and stuff, which if true is going to make my life even harder. If possible, I'd like to maintain the ability to control the shocks electronically in the spirit of keeping the car stock.
If anyone has any tips or wants to console me via forum, that would be great.
Cheers :)
Top
 Profile
PostPosted: Mon Sep 26, 2016 5:49 pm
Offline
you should have no issue with JZX100 parts from North Shore Toyota, they can get anything for you from Japan dude.
_________________
E-GX81-AEPQF. 8E3, FB81
Top
 Profile
PostPosted: Mon Sep 26, 2016 10:16 pm
Offline
The Problem is I have a JZX101. But that's reassuring, haha.
I was just worried as there seems to be zero second hand parts around.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
skymiles v1.1 designed by CodeMiles Team -TemplatesDragon-.
