These particular brakes are off an sxe10 beams Altezza unsure if other models have the same setup
Rotor diameter
Rotor height/ thickness
Altezza pad carrier on cresta hub
If you keep the cresta hub you'd need to trim the rotor back plate so if possible itd be better to use a complete Altezza hub from Upper to lower ball joint
Calipers
Stock
Altezza
Wheel clearance (18x8.5 +30)
Hope to buy all this stuff for my car soon!
Also wondering if anyone knows if the brakes that have Altezza stamped on them are of similar specs? (and perhaps another potential upgrade)
Cheers!
