got a problem with my
jzx90 1jz non turbo =((((
when the car is cold it will start fine and engine check light goes up starts fine
but after running for about 20ish min the car will just die. i.e. no hesitation no sputtering itll just stop
then trying to restart car the engine check light wont come up at all till engine seems to be cooler again
other question is does anyone on the north shore of auckland have a dizzy and/or an ecu i could borrow for a couple days to test it???
any help would be much appreciated just wanna get my baby back on the road AGAIN
1jz ge dies when warm??
Re: 1jz ge dies when warm??
have you tested for fault codes your self buy bridging te1 and e1 ?
got it sorted was a dodgee relay to the ecu so rigged up a switch for now
""why killswitch?.......................Because RACECAR!"
