to hi flow your turbo or not to?
Re: to hi flow your turbo or not to?
So what do you need from the CT26? Is it possible to get a slightly damaged one?
its better to get the whole thing, as you only really need the center core. if the compressor wheels are damaged i really wouldnt worry about it all that muchshweatypox wrote:So what do you need from the CT26? Is it possible to get a slightly damaged one?
Could you get away with this
bang on the mula dude
the core and shaft is all you will need
so all good even if it has play in shaft?
nah doesnt matter as it will be rebuilt anyway
is a caldina gtt turbo ct26?
It's a 3sgte but I think it uses the ct15b
AJ, doesn't the Caldina use a CT20B?
I thought the newer gtfour caldinas use the ct20b
