how big is the 3076?Mike wrote:the 3076 is pretty much ideal for the 1j, spool is pretty awesome and bugger all lag.
Def the best choice for up to 400ps
im wondering if im getting the 3037 and 3076 mixed up
Jayzedex100 wrote:Hey Jarrod, how much power does your car make with that turbo now? Did Murch say how much it could handle?
I want a nice little bolt-on turbo, but those top brand Jap ones are ridiculously priced (at least in our money/current exchange rate). I'd go high-flow over Rasty/HPI/HKS/Trust bolt-on jobs, just because of the price factor.
If it cost $1500 for a high-flow, and it could handle around, lets say 380hp, I'd consider that very worth it, considering you won't get anything cheaper if you go Japan style, which are all over 2.5k
yuk 7mgte lolshweatypox wrote:I think I had a ct26 on my gt4 (3sgte), did they also come on the 7mgte's? Or are the better ones off the diesel hilux?
the actuator was left standard, but the port size was increased, one of the best things you can do to a std oem spec ct15b is jam on the HKS 1 bar actuator, and set it correctly...even if you high flow it you still will need a good exhaust and actuator set up, other wise it all pointlessJayzedex100 wrote:Cool. It would be good to know exactly what he did with it. I'm curious to know what was done with the actuator side of things.
Where can a CT26 core be sought?
fully agree, you have to go into this with a resonible amount of knowledge ( at the time i did not know zip about this type of thing, but yarned to steve for a very very long time and learnt alot ) and an understanding as to what you want to do with the turbo and what you are trying to achevie as there are alot of options out there, some not so good some very very very goodPSIBRG wrote:stuff
