1jzgte vvti camshaft
Posted: Sun Dec 11, 2011 9:14 pm
by ping
Does anyone know where can I get a aftermarket camshaft without changing the valve spring? Prefer 272. Is that ok if I only change the EX side instead of both side? Does it make a lots of gain?
Re: 1jzgte vvti camshaft
Posted: Wed Feb 08, 2012 7:51 pm
by Caruna
I definatly would not recommed putting a cam with that high duration in without changing your valve springs, they will almost certainly coil bind. You would make some gains but not a huge amount. But yes you can change one side without doing the other.
