Does anyone know who sell camshaft for 1jz VVTI?
Is that good if I only change the exhaust side as the VVTI side need a controller to set up.
1jz VVTI camshaft
Re: 1jz VVTI camshaft
i'll have a set of both inlet and exhaust cams for sale in a few weeks time .
specs on cams?
Logan
Logan
I've got a set of HKS 264s going in the 1JZGTE VVti very soon , once I have the old cams out I'm sending them away to have the HKS cam lobe profile copied on them .ch4sernz wrote:specs on cams?
Logan
I talked t okelford over a year ago and they said they were working on vvti cams and that they would be available off the shelf soon. still nothing showing as available at this stage...
Your replacement cams are designed to work with stock cam gears and vvti?
Logan
Logan
Where do u get it from? How much does it cost?VR25 wrote:i'll have a set of both inlet and exhaust cams for sale in a few weeks time .
north shore toyotaWhere do u get it from? How much does it cost?
