2jzgte injector queries
- twojayzeejza
ok so found the problem with my supra not starting was that only 2 injectors were actaully opening, (pulse is fine etc) so took em out and blasted a bit of air through em. 4 work fine now but 2 dont even click but resistance is same as rest are they toast? who has some 2jzgte kicking around? cheers
Re: 2jzgte injector queries
get them ultrasonicly cleaned dude
this makes a massive difference, and restores the flow rate of the injectors
http://www.youtube.com/watch?v=ZJmdvoZ83hY
- twojayzeejza
managed to do a deal with matt dunn on toyspeed for some that have already been cleaned and flow checked
