Starter motor
Posted: Fri Jul 08, 2011 10:34 am
Hey just curious. could i run a vvti starter motor on my non vvti engine? Just cause i cause potentially get one from pick a part.
Aw you legend yea mine us playing up, therefore decides it doesn't want to start at very inconvenient times.ryanfels wrote:I have some 2jzge starter motors you can try if you need one
Oh yea i might try that then. Needs a cambelt soon anyway so il probly just do it all at the same time.Jonno2002 wrote:you could fix it, probly just needs contacts/plunger and/or brushes.
If you need one, let me know. My number is 0274246544Bosozoku_GX71 wrote:Aw you legend yea mine us playing up, therefore decides it doesn't want to start at very inconvenient times.ryanfels wrote:I have some 2jzge starter motors you can try if you need one
lol i havent changed a cambelt on any of my toys yet, the 1ggte has had the head off twice and just put the belt back on, even when i changed the cam/crank seals on the 1jzgte i just put the belt back, non-interference so i couldnt care lessBosozoku_GX71 wrote:Oh yea i might try that then. Needs a cambelt soon anyway so il probly just do it all at the same time.Jonno2002 wrote:you could fix it, probly just needs contacts/plunger and/or brushes.
]Jonno2002 wrote:lol i havent changed a cambelt on any of my toys yet, the 1ggte has had the head off twice and just put the belt back on, even when i changed the cam/crank seals on the 1jzgte i just put the belt back, non-interference so i couldnt care lessBosozoku_GX71 wrote:Oh yea i might try that then. Needs a cambelt soon anyway so il probly just do it all at the same time.Jonno2002 wrote:you could fix it, probly just needs contacts/plunger and/or brushes.
