Two throttle cables
Posted: Thu Jun 02, 2011 12:52 pm
Ok I feel like a bit of an idiot for asking this so go easy
What is the purpose of the second throttle cable on my 2JZ-GE? I've got one that is connected to the happy pedal, and one that runs down to the middle of the firewall area and disappears, though i'm not sure where to.
Some of you will know i've been trying to solve a high idle/cruise rpm problem. I identified one throttle cable as the one that goes to the accelerator pedal. The other cable still revs the motor when pulled on, but I thought it wasn't hooked up to anything so I never took a second look at it.
Turns out this other cable has been binding occasionally, causing the throttle to be held open slightly. I disconnected it, and now running only off the accel pedal cable, took it up the road quickly and it seemed to run sweet..
I can only think it might have something to do with traction control, but really thats just a stab in the dark. Do I need this second cable at all? If not i'll just leave it disconnected and call it problem solved!
