Electronic Boost Controller install
I grabbed me an EVC-III and want to know if someone has one, or similar, installed? Do I have to worry about a stock solenoid or can I just wire the thing straight up to the vvti 1j? Any help or photos would be great
Re: Electronic Boost Controller install
i hooked up my evc-s and blitz sbc id -II up not worring about the vvti set up..just basicly a straight install
has this one got the big dual soleniod? or the single port one?
just have a high and low boost setting and you will be fine
it would be interesting to here what you have to say about the evc.. i personaly dont like it and want my sbc- II back
I wasn't sure which one to get but a couple of peeps mentioned the EVC III and up so I just got that one. I'll hopefully have it in this week so I'll let you know how it goes.
fully
im by far no techno boffin and hat wires and anything push button, found the evc-s rather hard to sort out, but i beleve the evc-II is different and alot better than alot of the newer stuff coming out
dual soleniod is by far the best tho
