jzx90 cresta open diff - torsen LSD swap
Re: jzx90 cresta open diff - torsen LSD swap
- Contact:
Does that subframe differ at all from my current Tourer S subframe? i would imagine they are the same.
Yup pretty sure all Tourer subframes are the same.
Are you sure tourer's have same diffs? On x110 chassis only the IR-V's and G-tb's get the 8" diff and subframe. Could be different on the x90/100
Hmm, well I haven't personally seen a Tourer S subframe so i'm basically just going off of what I've heard. I do know for a fact though, that JZX91's got 8" diffs even though their subframes only have the single diff mount.
So JZX110 IR-S got 7" diffs?
Non turbo x110 come with 7.5" diff. Pretty sure altezza diffs fit as well cause the rear subframe is the same or very similar. I think the mounts are the same as wellPSIBRG wrote:Hmm, well I haven't personally seen a Tourer S subframe so i'm basically just going off of what I've heard. I do know for a fact though, that JZX91's got 8" diffs even though their subframes only have the single diff mount.
- Contact:
I suppose i should just bite the bullet and buy an F-series Altezza diff and see if it works?
anybody know of one for sale?
http://www.trademe.co.nz/823049327xMRWHIPPIEx wrote:I suppose i should just bite the bullet and buy an F-series Altezza diff and see if it works?
Here you go mate. A02B 4.1 ratio I think. By the looks of it, the rear mounts look identical to x-chassis ones.
You can also go there and check it out. That way you can compare the similarities and difference between the two diffs
Altezza Diff will fit, need 7.5 axles if changing from 8 inch. Put a 7.5 altezza lsd and axles in my tourer v. which had 8 inch diff.
