Page 3 of 4
Re: jzx90 cresta open diff - torsen LSD swap
Posted: Mon Dec 15, 2014 2:20 am
Posted: Mon Dec 15, 2014 2:10 pm
by xMRWHIPPIEx
Does that subframe differ at all from my current Tourer S subframe? i would imagine they are the same.
Posted: Wed Dec 17, 2014 7:40 am
Yup pretty sure all Tourer subframes are the same.
Posted: Wed Dec 17, 2014 11:49 am
by yakuza
Are you sure tourer's have same diffs? On x110 chassis only the IR-V's and G-tb's get the 8" diff and subframe. Could be different on the x90/100
Posted: Wed Dec 17, 2014 12:44 pm
Hmm, well I haven't personally seen a Tourer S subframe so i'm basically just going off of what I've heard. I do know for a fact though, that JZX91's got 8" diffs even though their subframes only have the single diff mount.
So JZX110 IR-S got 7" diffs?
Posted: Wed Dec 17, 2014 10:01 pm
by yakuza
PSIBRG wrote:Hmm, well I haven't personally seen a Tourer S subframe so i'm basically just going off of what I've heard. I do know for a fact though, that JZX91's got 8" diffs even though their subframes only have the single diff mount.
Non turbo x110 come with 7.5" diff. Pretty sure altezza diffs fit as well cause the rear subframe is the same or very similar. I think the mounts are the same as well
Posted: Thu Dec 18, 2014 10:01 am
by xMRWHIPPIEx
I suppose i should just bite the bullet and buy an F-series Altezza diff and see if it works?
anybody know of one for sale?
Posted: Thu Dec 18, 2014 3:08 pm
by yakuza
xMRWHIPPIEx wrote:I suppose i should just bite the bullet and buy an F-series Altezza diff and see if it works?
http://www.trademe.co.nz/823049327
Here you go mate. A02B 4.1 ratio I think. By the looks of it, the rear mounts look identical to x-chassis ones.
Posted: Thu Dec 18, 2014 3:11 pm
by yakuza
You can also go there and check it out. That way you can compare the similarities and difference between the two diffs
Posted: Thu Dec 18, 2014 10:27 pm
by luc3unitJZX
Altezza Diff will fit, need 7.5 axles if changing from 8 inch. Put a 7.5 altezza lsd and axles in my tourer v. which had 8 inch diff.
