Page 2 of 3
Re: Turbo Selection
Posted: Tue Apr 08, 2014 3:54 pm
E85 is cheating!
It'll be just under 300kw on 98
Re: Turbo Selection
Posted: Wed Apr 09, 2014 10:09 pm
by im_oli
Yeah I have a D-Jetro PowerFC (so runs MAP sensor + I've kept the car 100% Japanese so far) I'm hoping that will hook up some good gains.
But yeah I reckon Murch high flow will be the way to go for bang for buck! Plus then I don't have to change my manifold or dump etc. He's been replying facebook pms but big delay. Slow coms. Which makes it hard to suss out what he will actually do to it.
I've never really got into turbo specs etc so far, so bit of a learning curve, so to speak. A whole lot more rwkw's would stoke me. Tricky getting the right recipie though.
Re: Turbo Selection
Posted: Wed Apr 09, 2014 10:42 pm
by yakuza
im_oli wrote:Yeah I have a D-Jetro PowerFC (so runs MAP sensor + I've kept the car 100% Japanese so far) I'm hoping that will hook up some good gains.
For me, a responsive 260-270 kw would be perfect. Enough power to have fun but still be able to use the car as a daily
Re: Turbo Selection
Posted: Thu Apr 10, 2014 8:19 pm
by im_oli
Yeah hardout, I'm hoping for something like that.
Re: Turbo Selection
Posted: Thu Apr 10, 2014 9:12 pm
by yakuza
im_oli wrote:Yeah hardout, I'm hoping for something like that.
High flow should be more than enough if your aiming for that sort of power and response
Re: Turbo Selection
Posted: Thu Apr 10, 2014 10:21 pm
by im_oli
IF I can make it actually happen!.
Re: Turbo Selection
Posted: Fri Apr 25, 2014 1:19 pm
by 1jzSoarer
I am making 304kw atw on just a Tomei and Link. The turbo is great. It boosts early and even on limiter it hasn't stopped pulling. Very drivable but loose when you want it to be. I looked into this and without the hassle of changing the manifold you are limited and a good manifold is going to set you back another 1k
Google Supra Store for some nice kits from the States as a option
Re: Turbo Selection
Posted: Fri Apr 25, 2014 1:52 pm
by yakuza
1jzSoarer wrote:I am making 304kw atw on just a Tomei and Link. The turbo is great. It boosts early and even on limiter it hasn't stopped pulling. Very drivable but loose when you want it to be. I looked into this and without the hassle of changing the manifold you are limited and a good manifold is going to set you back another 1k
When does your turbo hit full boost? I thought the Tomei turbo was laggy, could be wrong though
Re: Turbo Selection
Posted: Sat Apr 26, 2014 9:10 am
by davealdworth
The tomei's are pretty laggy. Phil mentioned in his thread it was around the 4-4.5k mark. Seems to be the same as most of the tomei guys around my way.
How did you go with the Suprastore 1jzSoarer? Haven't heard anything good from the Aussie guys who have used them. There's threads all through the supra world stating to steer clear.
Re: Turbo Selection
Posted: Fri Jun 06, 2014 11:13 pm
by Naaste
Mate has used supra store for mani for jzs161 to go to t51r, didnt have any problems and got aem ecu from them aswell. T51r spooled up not too late on 2j with auto. Murch has his phone number on his facebook page. I spoke to him other day. $650+gst for hi-flow setup bit more to go to the ct26 internals as more machining. I liked the gt30 on mates chaser which was easily driveable. Much better now though with gt35 and poncams waiting for a ride in it now!
