max out 1jz injectors?
jakwoo39
Post by jakwoo39 »
hi guys new member and i dont have a jzx but this seemed like a good place to get some info on 1jz tuning
its a 90s hilux 2wd with a non vvt 1jzgte
internals are standard as far as i know
link g3 ecu
t3t4 turbo
stainless mani and full mandrel bent exhaust
fmic
external fuel pump
standard injectors
what do people think i can get out of this setup without having to fork out more $$$ for bigger injectors
currently its running quite low boost with little over standard power ill be getting it re tuned after christmas with a high boost switch how much are other people getting on standard injectors?
yakuza
Re: max out 1jz injectors?
Post by yakuza »
jakwoo39 wrote:hi guys new member and i dont have a jzx but this seemed like a good place to get some info on 1jz tuning
link g3 ecu
t3t4 turbo
fmic
external fuel pump
standard injectors
You should get 2jzgte injectors (440cc). They're suitable for around 280kw I'm pretty sure. They're also pretty cheap, probably around $150.
slipwaysailplane
Post by slipwaysailplane »
Yep 2jz injectors are cheap as chips. dont bother with stockers. they are prolly good for 320hp or so
Post by davealdworth »
what about the SARD injectors and fuel rail to suit? They are rather tasteful and are goo for 400hp+ from what I've read
