1JZGTE help
Invisty
1JZGTE help
Post by Invisty »
Afternoon Guys,
I'm having some trouble with my 1JZ soarer.
Typically it starts fine the first time you start it, but on subsequent starts immediately after driving the car will die. The revs dip until it stalls completely.
However after roughly 10 minutes it'll start up and run happily.
Any ideas? or willing to attempt diagnosis, I live in Central Auckland.
The car is totally stock and pretty high K's (240 000)
Any help appreciated, cheers
slipwaysailplane
Re: 1JZGTE help
Post by slipwaysailplane »
Try another ecu, some of the cap's inside tend to stuff out.
Invisty
Re: 1JZGTE help
Post by Invisty »
anyone got a spare 1jzgte ecu for me to test this? Many thanks
driftouteast
Re: 1JZGTE help
Post by driftouteast »
I have one that isnt being used at the moment, i could come round and try it out if you need?
Invisty
Re: 1JZGTE help
Post by Invisty »
driftouteast wrote:I have one that isnt being used at the moment, i could come round and try it out if you need?
hey man that would be ideal, drop me a line 021 171 9006 and we'll tee it up
Jonno2002
Re: 1JZGTE help
Post by Jonno2002 »
mine does the same on both ecu's i have and neither have leaking caps, only does it when the motor is hot and has been off for a while then go to restart it and it dies first 2-3 starts then starts and runs mint.... fuck knows havent been to bothered with it to be honest.
Matt K
Re: 1JZGTE help
Post by Matt K »
afm?
do 1jzgte's have an afm?
archon
Re: 1JZGTE help
Post by archon »
^ TT 1jz are MAP.
Have you ruled out the fuel pump ecu? Common issue on JZZ30s, and can cause the symptoms you describe.
In the diagnostics port in the engine bay, bridge Fp and B+, a piece of decent wire should do, or a paper clip. With this done you should hear the fuel pump running as soon as the ignition is turned on, and if the FP ecu is faulty the car will run and start fine.
You can run it bridged semi permanently, but the fuel pump won't stop if you crash the car and the engine stops.
lolyf
Re: 1JZGTE help
Post by lolyf »
Bridging Fp & B you dont need to turn on ignition.
I suoprt pulik ejukashun!
