Power FC
Re: Power FC
I hear that Soichi will only touch your car if its super clean?
Re: Power FC
haha you shouldve seen my POS when it went in there. 3 different colours no bumpers on the back of a trailer.ryanfels wrote:I hear that Soichi will only touch your car if its super clean?
Maybe coz im asian.
Re: Power FC
or toyotas...
had quite abit of work done by kent and hes ok but
would use someone else next time
Re: Power FC
nothing wrong with the power fc
they have released a newer version i beleave
aj ( unstable ) has a power fc in his jzx100 with good results 241rwkw????? cant remember but i was mega jealous
mega jealous
also have herd alot of pple using z32 turbo afm along side the power fc in the vvti 1jz'x
unsure as to why yet
mega jealous
Re: Power FC
they do it because the standard afm only supports around 300kw afaik,
whereas the z32 afm is much bigger and capable of more power.
Re: Power FC
Z32 from memory has more flow capabilities and give a better resolution for tuning when you have outflowed your stock afm and pegged it on a constant peak voltage reading.
Was thinking about Kent as he is the closest to me up North here, other option is to wait for Tricky to be over from OZ
Logan
Logan
Re: Power FC
i also run Z32 AFM and Power FC have a option built in to select it. (Would still need a tune though)
Re: Power FC
yeah power FC is all good, 170-180kw stock ecu on 1bar and 227kw tuned on 1bar also.
as for tuning, ST hitec or STM only. (speedsorce if you have a subaru or a mitsi!)
I also had issues with speedsorce's tune, it was all fixed by Soichi.
I also hear that the stock AFM is finished at 260rwkw, so will be doing Z32 when I have my turbo etc done.
Re: Power FC
Get that turbo done you homo. I want pfc sooo bad.Unstable wrote:yeah power FC is all good, 170-180kw stock ecu on 1bar and 227kw tuned on 1bar also.
