1JZ dying and stalling
Posted: Tue Aug 06, 2013 7:24 pm
by JZ14
Hey guys, I've put a aftermarket fuel pump in my car (DW200) and wired the fuel pump at a constant 12V. I think it's pumping too much fuel in (huge clouds of black smoke when revving) and as soon as it hits the idle mark on de-accell, it just dies.
I've got a fuel pressure reg, and it's reading 3bar (43psi), so I think thats all good, but just wondering what you guys think this could be? This is a new engine to me, and it's not in a Toyota chassis.
I'm thinking maybe water temp sensor? (the fans don't appear to come on when hot either) but seems too simple to be the problem.. How could I test this?
Thanks in advance
Re: 1JZ dying and stalling
Posted: Tue Aug 06, 2013 9:24 pm
by lolyf
Being a bit more specific than "1JZ" would help
. Not your water temp sensor. Wouldn't start cold. by your definition, i'd say its a vacuum hosing/map sensor issue. Look around where you installed the FPR.
Posted: Tue Aug 06, 2013 9:39 pm
by JZ14
Sorry, I'ts vvti GTE.
I've sprayed CRC all round the FMIC joiners, no leaks from what I can see. Also disconnected the TPS whilst running, and reconnected, no difference
Posted: Tue Aug 06, 2013 10:14 pm
by lolyf
Start by checking, rechecking and then checking some more for air/vac leaks past MAF. Reduce fuel pressure to 30 psi (especially if rising rate). Report back. Post photos, especially of burnouts. I like burouts.
Posted: Tue Aug 06, 2013 10:16 pm
by JZ14
I will be doing garage burnout 100% when it gets going.
I also love burnouts.
Posted: Tue Aug 06, 2013 10:22 pm
by lolyf
in case of above post video!
EDit: Check BOV if vented to atmosphere.
Posted: Wed Aug 07, 2013 10:33 pm
by JZ14
BOV is all stock, haven't touched it at all.. Heres what my engine looks like, If anyone can see anything dumb i've forgotten/thats wrong?
All vac lines seem plugged in? Just this one that I can't find, but I'm guessing its from the TRC?
We checked fault codes, came up with 27, 32 and 47.(O2, AFM, and TRC?) So fucked around with the throttle body a bit, didn't change much.
We 'Reset' the ECU, and you can hear it learning as its spluttering a long now, backfiring and stuff.
Called it a night, but then I pulled the plugs, found this;
Will one plug not firing cause it to die with revving it/de accell?
I'll throw new plugs in tomorrow. Haven't lowered the fuel pressure yet either, will also try that tomorrow too.
Posted: Thu Aug 08, 2013 3:00 am
If it's throwing afm and o2 sensor codes, I'd start with those, in fact I'd probably put money on it being an afm issue. Maybe see if you can borrow one off someone, if yours is kak'd that would definitely cause issues. I've killed afm's on my Mitsi before and it makes the car run like a pack of arse..
Posted: Fri Aug 09, 2013 9:17 pm
by lolyf
^ That
Check +B to ECU.
Posted: Sun Aug 11, 2013 6:03 pm
by JZ14
Put new plugs in it, runs like a dream.
Just need to get it to drop its idle when warm now!
