1jz VVTI injectors
1jz VVTI injectors
What size are the stock injectors in my jzx110? Also if I were to upgrade them what would I be looking for? top or side? high or low? Could I grab some slightly bigger ones from a 2jz? Would the xr6 turbo ones work?
Re: 1jz VVTI injectors
IR-V injectors should be the same as JZX100 Tourer V ones which are 370cc.
If you are upgrading, you will need the pencil looking injectors (not the stubby looking ones) which are top feed and high impedence.
3SGTE injectors are drop in and are 540cc. I'm using these in my new setup.
I believe the SARD injectors (540cc) are exactly the same.
anything more than 550cc is a bit overkill unless you are planning on running E85 or want to put down more than 350kw.
Hey mate ive got some Sard 530cc top feed injectors I have just removed from my jzx100 that will bolt straight in. $600 incl delivery. Only had them in for about 10,000kms then upgraded. Let me know if your keen.
Cheap wastegates cost motors
I thought the 3sgte were only 440cc or are they from a newer 3sgte?Tofu wrote:IR-V injectors should be the same as JZX100 Tourer V ones which are 370cc.
Cheers Caruna, I may have some lined up already but I will hit you up if I need themCaruna wrote:Hey mate ive got some Sard 530cc top feed injectors I have just removed from my jzx100 that will bolt straight in. $600 incl delivery. Only had them in for about 10,000kms then upgraded. Let me know if your keen.
Theres a full bolt on sard injector and fuel rail
http://www.perfectrun.jp/src/detail.php ... 0054_10013
