On the front of the timing cover, there's a white sticker. Mine says S2, but I have seen others like, J2 etc
eg J8;
Edit: Also, the top radiator hose, does it have to come across the engine like it does from factory? Or can I cut the pipe and re-weld it so it just goes straight, rather than the 90* bend it has? IE like this;
Everything is going to be stock for now, minus aftermarket radiator.
Thanks guys.
