http://www.bm-kofu.com/parts/gallery147.html
pretty sure that says wiring is different auto to manual so manual ecu wont work on a auto
this guys appears to have tried it to although it is a blit wagon
http://jzxproject.com/bbs/index.php?showtopic=8260
one of you more intelligent guys might be able to work out what the Japanese guy did with the ecu pinouts
jzx110 manual convo wiring
Re: jzx110 manual convo wiring
http://minkara.carview.co.jp/en/userid/ ... /29263563/
this appears to be the answer
wish I knew what it was on about
What speed sensor are you using? Its usually a waveform/correction that'll set off that light.
edit checked the box
there's a 3 pin speedo at the rear drivers side of the box
not wired up at the moment I was told 100's speedo ran off the diff wrong obviously
http://imageshack.us/photo/my-images/20 ... gs005.jpg/ black plug with the neutral start wiring
http://imageshack.us/photo/my-images/52 ... gs004.jpg/ grey plug from the rear passenger corner of the auto box
http://imageshack.us/photo/my-images/70 ... gs006.jpg/ then there 2 of these abs sensors
if anyone knows which three wires from which plug are for the speedo I'll wire that up and see what happens
reverse light wires would be good to know to
The three pin is the speed sensor with pinouts IGN, Ground and SP1, Yello, Black and Light blue/red. The Lblue-red goes to the dash. Trace the NSW wire on the plug near the trans, Give it +12V while cranking (use STA) she should start right up.
Edit.
The reverse lights shoutld be a +12 switched, trace it out, should'nt be a problem.
Edit.
cheers mate actually got is sus'd and driving tonight before checking your post
got rev lights working speedo working
but I do have the check engine light described in the japanese blogs and trc seems a bit
strange just no power between 3.5k- 5.5k if its on
Must check if rear tyres are making screeching sounds... TRC switches ON if you do skids...1400r wrote:cheers mate actually got is sus'd and driving tonight before checking your post
Disconnect TRC plug and try. Try getting a DTC. Short pin 13 and 4 on your DLC. Its probably going into limp mode. Your ABS and TRC ECUs recieve the speed signal from the engine/ECT ECU. On the 16 pin plug check voltage at NEO on Engine Ecu and NEO of the ABS /TRC ecu. Its a +signal, ground and check. You Should've 3-5v and under 1v pulse with engine idling.
you've got way more faith in my skills than I have
but thanks for the info
