My names Toby, I'm from NZ and I live in tokyo, Japan.
I have two jobs, I work at a kindergarten before lunch and then go spend my afternoons and evenings working at a car shop called Shino kouba. Maybe someone knows it but it's fairly well known here in Japan.
I've only owned shitty nissans up till now and after having endless little issues and good old sr20s running bearings I decided it was time to make the switch! A few of my friends who I drift with here have crowns and since there are endless chasers, mk2s etc I decided I would try build something to drift that was a little different even here in Japan! So I've picked myself up a jzs171 crown athelete v (jzx110 running gear) and I'm slowly getting all the parts together to build something cool.
Excuse the next two photos :p one does have a jzx100 in it for every one!
My cefiro I owned in NZ before moving
I owned this 180 for almost 9 months over here and I guess it took a fair beating on Touges and the ports before I saw the light/some amazing runs on mountains with my mates jzx/jzs and got my hands on something better!
My 171 crown. 1jzgte, auto (never made manual)
The engine is the same as a jzx110, so I have a quick question in regards to my trans swap, who has done it on a 110 and what did you do ecu wise. Even here no one can give me a straight answer. A good friend of mine is running his AT ecu and says he has no issue but I did here somewhere else that maybe the vvti won't work properly? Excuse my ignorance incase this is a basic question because I really know nothing about these engines/chassis.
Anyways I look forward to hanging around on the forum and if you have any questions then feel free to send me a message!!
Cheers!
