Thank you. I will and as soon as I get on the computer ill add some photosyakuza wrote:Just to clear up things, I had no intention of hating. Good luck with your build and keep us updated
my 1st build.
Re: my 1st build.
Re: my 1st build.
driveshaft will have to be custom, you can use the front shaft from the chaser but you will have to have custom work either done to the chaser shaft to mate it to the skyline diff or you may be able to use the skyline shaft and custom work it.
Look on the skyline forums around the place (particularly the aus ones). You should strike it lucky and find a guy who specialises in it. Over here they love the conversions just as much as NZ but the resources in places like Sydney and Melbourne are amazing
Re: my 1st build.
actually on top of that try these guys. They're in the states but they know their stuff and do fantastic work. Can be a little pricey but for the perfection they provide its worth it
http://www.driveshaftshop.com/
Re: my 1st build.
Where are you in the country?
I've just put a VVTi 1JZ into my S14.
Throttle cable i used was a 2E, It's a little long (2-3mm), but it works, you just have to adjust it correctly. I needed a C33 swaybar (I think they're same as R32?) Fuel lines are also a pain too.
You have to go custom drive shaft, There's no way you can do a Toyota to Nissan coupling. Mine cost me about $400 all up balanced as well. I recommend doing two piece as well.
My build came in over 3k more than what I had budgeted (And I thought i budgeted 2k more than what I was going to spend)
Re: my 1st build.
$400 sounds like a bit much?! Just putting a toyota yoke onto a nissan shaft shouldnt cost much. Not as much compared to the rest of the conversion anyway
Re: my 1st build.
They're different size tubes.. The Nissan one was a lot bigger in diameter
Re: my 1st build.
Wow thanks for all the info guys.
im i hamilton and a 2e cable from what kinda vehicle wouldnt the body chane the length? Yea I read up on fuel lines. Few people rekon just run hoses around and heat shield them but surely with the tool to flare the tips for hoses it cant be hard to trim and bend where needed??JZ14 wrote:Where are you in the country?
You have to go custom drive shaft, There's no way you can do a Toyota to Nissan coupling. Mine cost me about $400 all up balanced as well. I recommend doing two piece as well. )
Re: my 1st build.
Also have come across a few places in my city that can do the conversion for driveshaft ends. So ill have a chat with them and see what they reckon. Im sure they would be ablebto sus me out woth something. I hope
Re: my 1st build.
for the fuel lines if it becomes too much of a hassle maybe look at running braided lines. That way you can tidy the whole lot right up and give it a nice look aswell
Re: my 1st build.
U mean braided straight from the fuel tank?? If thats the case I might go after market tanknin the boot.it would make my bro happy as id have to strip my boot out. Not to go on and on or anything but I havnt seent such a flawless boot lining still intact and un disturbed before. Not even a stain. But my mate has a 32 and has been bugging me for it haha
