1jZGTE Marathon Jetboat
Posted: Sun Jun 09, 2013 8:48 pm
by jetboatkarl
Hi Karl here, am based in Rotorua.
Here is something a bit different.
A 23 foot Keelowcraft tunnel hull boat fitted with a 1JZGTE.
The engine internals are standard (for now), but the head has a backcountry port job. Runs a single Holset HX-52 turbo, LS2 truck ignition coils and a Wolf ECU. Have a WB-O2 wideband and Haltech knockears for tuning.
Re: 1jZGTE Marathon Jetboat
Posted: Mon Jun 10, 2013 1:02 am
by m989
Awesome! How long did it take to build? Any idea what its top speed might be?
Posted: Mon Jun 10, 2013 7:31 am
Holy bejesus this thing is awesome!
Being in the water means the giant turbo isnt much of an issue with less resistance to the motor? (In regards to lag)
Posted: Mon Jun 10, 2013 11:19 am
by murdoko
NICE! JZ Powaarrrr!!!
Posted: Mon Jun 10, 2013 11:36 am
by jetboatkarl
m989 wrote:Awesome! How long did it take to build? Any idea what its top speed might be?
About 2 years to build as did everything ourselves. Does about 75-80mph at the moment. Still have to play around with the trim and jetunit intake to get it flying properly.
Posted: Mon Jun 10, 2013 11:41 am
by jetboatkarl
Tofu wrote:Holy bejesus this thing is awesome!
Yep that's correct as the jetunit doesn't really load up until 4000 rpm.
Motors get a hard time in a race boat as often you can run 20psi boost 5,800rpm for 30minutes without lifting off. Generates a lot of heat!
Posted: Mon Jun 10, 2013 12:03 pm
by jetboatkarl
Here is a vid of our first testing. Had a Holset HX35 on it then. Crank the sound up!
m2x6AfGr_WA
Posted: Mon Jun 10, 2013 6:35 pm
jetboatkarl wrote:Motors get a hard time in a race boat as often you can run 20psi boost 5,800rpm for 30minutes without lifting off. Generates a lot of heat!
How do you cool it?
Posted: Mon Jun 10, 2013 10:36 pm
by jetboatkarl
How do you cool it?
Raw water from the jet unit goes through a sandtrap (hydrocyclone) and then directly into the water pump, water leaves the head and goes overboard.
Posted: Tue Jun 11, 2013 6:46 pm
by Alex
what wolf ecu? who tuned it? my mate has a holset hx50 and wolf v500 ecu on his 1j and struggled to find a good tuner
