Some dyno runs before and after replacing my front pipe/cat gave me about 7ish rwkw and a little more boost. Plus it sounds a lot better
Alex wrote:if you get your factory turbo steel wheeled it should only set you back a couple g
get my injectors and rail + power fc and tune.. 5-6k max
I went to Japspares today and apparently they have 3 conversion kits that just arrived. 2x x100 and 1x x90. I'm pretty sure the important bits will fit my x110:dom wrote:You can convert it to manual for half that price if you get used parts. The only problem would be the interior bits which i'm guessing you'll have to get new.
Once its manual you'll most likely be happy with the power it puts out now(for the time being), which is wasted being in front of an auto
I'm thinking of this kit as well for mine as you can keep the standard manifold and dump pipe.Tofu wrote:[quote="murdoko]
the New Tomei ARMS M8280 bolt on kit for 1jzgte is only 1900 bux and capable of doing 450hp with just CAMS and an ECU tune... check the Tomei website![]()
