Have ordered one of these to add closed loop to my F-Con ECU:
An Innovate LC-2 which has pretty much just been released, from what I can see it has extremely good response time, and is very accurate - ideal since it will be controlling my off boost fuelling!!
http://www.innovatemotorsports.com/products/lc2.php
At the same time am going to get a re-tune and look to bump up boost a little more, and increase redline to 7500rpm - car is still making power with no tapering at current redline, will see if I can get to 450kw @ wheels!
I have also bought an HKS CAMP2 which is on it's way from Japan.
http://www.hks-power.co.jp/usa/categories/Pid=3470.html
A system that utilises my standard TV screen in the dash for monitoring of all useful parameters from either the OBD port, my F-Con ECU, or external sensors.
Of most interest is boost, trans temp, engine oil temp and pressure, exhaust gas temp, and intake temp.
Can also monitor all sorts of other things such as timing, water temp, throttle position, injector timing, calculated power, fuel economy etc.
And finally, have got a Fujitsubo exhaust on the way as well - a Legalis Super R, used, but good condition, 3" splitting to dual 3" with 4.5" rolled tips - minimal bends, but quiet and very well made.
