Spring rate for these bad boys is 12kgf.mm front and rear. Actually make for a really smooth ride and with the sway bars on the car sits extremely flat through the corners.
Oz has dealers for HSD's everywhere, pretty sure they are the most common breed of coilover here
Okay, so it's not stanced. so what?! function = form... took a bit of adjustment here and there to get to a "no-rub-no-scrape" setting...
notice anything new??
Yep. Got them installed mainly for protection for my newly fixed TRD bumper.. and of course, looks...ch4sernz wrote:Ez-lip?
looks good bro. Where did ya pick that up from?
Thanks! There's a supplier here in Auckland. However, you can just search "EZ-LIP" on ebay.com.audavealdworth wrote:looks good bro. Where did ya pick that up from?
only cost about 35 AUD
just to get rid of any doubt that my diff's LSD....
...definitely not open...
always thought it was LSD from the way it acts when I step on the gas while exiting a corner.... manufacturer's plate says B02B though so must've been replaced sometime in the past somewhere in Japan.
PS. drive sensibly
PS. drive sensibly
murdoko wrote:just to get rid of any doubt that my diff's LSD....
PS. drive sensibly
I refuse. Drive it like I stole it
B02B is a torsen isnt it? A B01B is a open diff. JZX110 auto came with a option, either torsen or open diff and since your one isnt a B01B it must be a torsen.
pretty sure all manual JZX110 came out with the torsen fitted like you said autos came out as an option only.
