Tofu - Phil's JZX100 Tourer-V
ch4sernz
Post by ch4sernz »
Might as well have! Jz's are so unknown up here I had a honda try and pick a race with me the other day!!!
yakuza
Post by yakuza »
Wheels look good, what sring rates did you go with the BC's?
Tofu
Post by Tofu »
12/8kg. Good combo for a street car. I've got them on full soft at the moment running in the shocks however i'll dial them up a little bit soon. (Full stiff is way too stiff)
I did notice these give the coilover 'bang' when you hit sharp bumps on the road.. anyone else notice this? my HKS didn't do it as bad however they were softer.
Got around to doing the first oil change today (Motul 300V) and fitting the front and rear KTS sway bars. Big difference! Sits so flat through corners now!
don't mind my maori diff mounts. they work well!
ch4sernz
Post by ch4sernz »
I'm also running 12/8kg and kts sway bars.
Run the fronts on full hard dampening and feel its a little soft
Rear runs around 2/3, gives awesome grip. Full hard on rear damper was quite jarring over bumps
PSIBRG
Post by PSIBRG »
Tofu wrote:I did notice these give the coilover 'bang' when you hit sharp bumps on the road.. anyone else notice this? my HKS didn't do it as bad however they were softer.
Yup, normal. You won't even notice it after a while.
Those KTS swaybars look pretty beefy. Quite a bit thicker than my Cusco's anyway. Are they solid, or hollow like the factory ones?
Tofu
Post by Tofu »
ch4sernz wrote:I'm also running 12/8kg and kts sway bars.
I noticed this too. The rear set on hard makes the car quite unbearable over bumps. Especially on the open road
Tofu
Post by Tofu »
PSIBRG wrote: Yup, normal. You won't even notice it after a while.
Feels like the wheels and suspension are taking a huge smash. Can't be too good for them!
The kts sway bars are the stiffest ones you can get for an xchassis from my research. Solid!
1400r
Post by 1400r »
kts are hollow and a few Aussie guys have had them break in half
cheap junk
http://jzxgarage.wordpress.com/2013/01/22/719/
guy removed the image but info is still down the bottom
Driftmonkey
Post by Driftmonkey »
1400r wrote:kts are hollow and a few Aussie guys have had them break in half
cheap junk
" KTS hollow swaybars are best, "
Isn't he saying the KTS ones are good.. or am I reading it wrong? or is it internet sarcasm?
1400r
Post by 1400r »
yep sarcasm as in the pic its snapped in half
