steady on Phil, you just bought a whole lot of stuff u didnt need
I see a bit of fog in that headlight, i consider myself a bit of a pro at these headlights
i have ruined one or two.
best idea use a stick with bit of rag taped on the end and poke it down the lamp hole and wipe it around, i found spraying window cleaner in there too broke up the dirt. but then again maybe it never crossed your mind..... car is looking sweeet keep up the good work
