1jz parts
Bosozoku_GX71
1jz parts
Post by Bosozoku_GX71 »
Hey guys I need an ecu from a 1jz-ge non vvti. I know jonno2002 has heaps of bits so I'm hoping he might have one lying around!
JZ = engine code
X = Chassis
71 = Series
therefore... jzx71
Jonno2002
Re: 1jz parts
Post by Jonno2002 »
i should have 1 or 2 lying around, ill have a look tomorow and get back to you, what happened to yours ?
Bosozoku_GX71
Re: 1jz parts
No idea but it was the cause of the missing. Apparently injectors 2 and 6 weren't firing or something and they traced it back to the comp. Just trying to decide if it wud be worth getting an aftermarket ecu instead tho
JZ = engine code
X = Chassis
71 = Series
therefore... jzx71
Jonno2002
Re: 1jz parts
Post by Jonno2002 »
i has 1, u have a pm :mrgreen:
