im looking for an open diff for my jzx90 chaser the diff code on the buid plate is b02a
from my knowlege this should be the larger pinion wheel with 3.7:1 ratio and a 2 pinion open
cheers oh this is urgent but i need a cheap one if poss please
![Smile :)](./images/smilies/icon_e_smile.gif)
Just so you know, you can't correctly ascertain the pinion size from the diff code. You have more chance of ascertaining the size from the engine/model of the car. If its non turbo, and non Tourer, chances are its the smaller diff. Also to double check, count the number of bolts on the stub axles. And I'm fairly sure they were all a 4 pinion diff...XQZIT X90 wrote:hey all
cheers oh this is urgent but i need a cheap one if poss please![]()
