WANTED: 2jz-gte stock twin turbo setup.
preferably everything you pulled off when you decided to swap to a big single turbo. compressor/bearing condition inconsequential as i will get them rebuilt.
mine are smokey and i need replacements. if you know someone who has a set sitting rotting in their garage rubbish pile kindly let me know
many thanks for any leads. thanks@@@!!
Re: WANTED: 2jz-gte stock twin turbo setup
I don't have a set of twin turbos but have a 2nd hand t4 single turbo manifold that I would sell cheap which could be a good upgrade for you.
stainless? chinese?
Is the pre-vvt 1jz twin turbo setup the same?
If so, you could ask Vash as he might still have his bits??
the manifold is not a chinese one, its reasonably old and is different design than chinese one, I came with a large garrett turbo and was a HKS set for 2jz-gte engines back in the 90s. stainless pipe with some bracing and has a t4 to v-band outlet so if you wanted to change the flange it makes it easy can just weld a different flange to a v band then you can swap whenever and dont have to hack up the manifold.
oh and btw 1jzgte non vvti turbo setups are quite different to 2jz-gte turbos , also the parallel vs sequential arrangement
