1jz parts
Posted: Wed Feb 23, 2011 5:57 pm
by moonboots
Might be a long shot, but im after some jzx90 1jay engine mounts the alloy bits that bolt to the motor and the rubbers.. also a factory jzx90 loom, for a 1jz
chur
Re: 1jz parts
Posted: Wed Feb 23, 2011 8:06 pm
by Mike
Might be able to suss you some mounts, will double check.
Re: 1jz parts
Posted: Fri Feb 25, 2011 9:43 am
by moonboots
cheers man, do you know if the Gx90 x member is the same as a jzx90?
Re: 1jz parts
Posted: Fri Feb 25, 2011 9:43 pm
by Mike
Yea 99% sure is the same
Re: 1jz parts
Posted: Sat Feb 26, 2011 12:21 am
by mephsto
ive got a set of engine brackets and rubbers from a jzx90 if your interested. also have a jzx90 1jzgte ecu
Re: 1jz parts
Posted: Sat Feb 26, 2011 12:41 pm
by moonboots
Hey. Am keen. How much 4 brackets and rubbers? No need 4 ecu, just the engine loom. Cheers
