Am after some stock 1jz conrods, can be 1JZGE (non vvti) or 1JZGTE vvti or non
Cheers Dan
1JZ conrods
Re: 1JZ conrods
i can help you if none come to hand. I have a set from a motor that i melted a hole in a piston on, if they are of any use to you.
1989 2jzx81 mark II project.
Re: 1JZ conrods
what condition are they in?BlakeNZ wrote:i can help you if none come to hand. I have a set from a motor that i melted a hole in a piston on, if they are of any use to you.
Re: 1JZ conrods
im in CHCHJZ14 wrote:Where are you located?
Re: 1JZ conrods
5 out of 6 are bent whoops
Re: 1JZ conrods
are you suggesting mine are bent, or that you have bent yours? (I can't view your image).
it take a special effort to bend those short, stout 1jz conrods.
Re: 1JZ conrods
Nah mine are hence why I'm after new rods for the motor, yeah head lifted and water got in the cylinders. Yeah there grunty rods
Re: 1JZ conrods
Hey man ive got a set of rods that have been shot peined in chch
Re: 1JZ conrods
that would be a big help, as i haven't sent him mine yet
too busy/too slack/whatever/sorry man.)
