1JZ-GTE Automatic
Ventourer
1JZ-GTE Automatic
Post by Ventourer »
Hey guys, i have the 1jz-gte out of the 100 and im going to fit it into another car an old school ride i want an auto box.
I have the manual ecu, R154 bellhousing slave cylinder and clutch flywheel etc. Anyone out there want to do swaps for a auto trans and ecu's?
ch4sernz
Re: 1JZ-GTE Automatic
Post by ch4sernz »
Why aren't there ten people jumping in this?
Agreed!
Ventourer
Post by Ventourer »
hey just to clarify this does not include the gearbox.
i need to add a few commas to my sentence.
i have the manual engine ecu, r154 bellhousing, flywheel, clutch, slave cylinder.
i might sell the engine complete with wiring loom and ecu if i get a good offer and put a dirty 1uz into the 66 crown.
im in no rush as i dont want to release anything till i know the new motor for the chaser is going to do what i want.
I certainly dont want a chaser with no engine hehe
I also think i might need the auto engine loom. not too sure, if anyone has ideas about that.
lolyf
Post by lolyf »
Ive got the a340e with both electric and cable extention housings. Lemme know what youre after
lolyf
Post by lolyf »
Will swap. Both trans in known good working order. Be warned though 5hat they're off the non turbo versions.
yakuza
Post by yakuza »
What are you doing with your chaser?
V12.
Ventourer
Post by Ventourer »
Yep V12. its ass puckeringly expensive so i suggest not doing it.
despite trying to go NA i just couldnt spend that money for that little HP so its being TT'd.
We have discovered that the 1JZ is not going to fit in this particular vehicle so will do a 1uz instead.
So the 1JZ with all the aforementioned bits will be offered for sale.
I dont want to sell for a while but if anyone out there wants to register some interest then we can start talking.
Motor has done 135,000 k's all legit, goes well, had cam belt, water pump etc at 118K.
yakuza
Post by yakuza »
Thats gonna be pretty expensive. Why don't you just sell the crown, buy one of the Toyota Century's on trademe and put the 1GZ in that and leave the 1JZ in the Chaser? :)
