JZX100 Torsen / Mechanical LSD
As per the title.
Cheers,
Phil
021647974
grippa
Re: JZX100 Torsen / Mechanical LSD
Post by grippa »
I wouldn't bother with a torsen if you are paying for a Lsd I would go for a mechanical !!!
I will be changing my torsen for a mechanical one day
They are just so more predictable
Does it act similar to the helical in the s15?
Thanks for the heads up Clint.
grippa
Post by grippa »
It locks and is nice and tight intact is quite aggreesive but opens on any de-excel ! It is good for coil overs with not much droop and is fine for a lock / burnout but I don't have much confidence in them if you like to get it out occasionally .
Sounds exactly like a R200 Helical.
I'll keep that in mind. Cheers
Anybody?
archon
Post by archon »
Have you checked all the wreckers?
There was a turbo JZX110 at Turners in the damaged vehicles a few months back that had an LSD. Not sure where it turned up though.
