Diff
Ruby
Diff
Post by Ruby »
Any one have stub axles for JZX100 diff ?
ch4sernz
Re: Diff
Post by ch4sernz »
Open diff or Torsen LSD?
7.5 or 8" crownwheel?
What are you doing?
Ruby
Re: Diff
Post by Ruby »
hi there, putting torsen diff head into celsior diff housing 8" need the longer stub axles which have the 100mm shafts.Mine are 90mm long and dont engage the c-clips.
ch4sernz
Re: Diff
Post by ch4sernz »
Only one stub axle is longer for Torsen.
My last set got used up.
Might be worth looking for a broken Torsen as an option as well.
Should be a few of those floating around the place
