WTD: 1JZGTE vvti valve covers
WATDA
Post by WATDA »
As per title, I am after both valve covers as the mechanic has over tightened them and now they have cracks and leaking oil.
Andrew
0274367463
JZ14
Re: WTD: 1JZGTE vvti valve covers
Post by JZ14 »
Wow!! Who did that?? It wasn't Ray was it?
slipwaysailplane
Post by slipwaysailplane »
i could try weld em up if no luck
WATDA
Post by WATDA »
Nope not Ray haha, at the other mechanic I took it too.
Got someone having a crack at welding it up at the mo. Farking hard to find
Looonie
Post by Looonie »
How did you get on with this Andrew?
Stupid new cam cover seals being thicker than old worn ones :\
WATDA
Post by WATDA »
Ended up getting them welded and it seems to hold it ok. Looks a bit rough but its covered up so that's ok!
Tofu
Post by Tofu »
Mine did the same thing. They are especially weak around the exhaust side.
